Won't start unless holding the throttle
Old Dec 29, 2018 | 01:26 AM
Moparman2001's Avatar
Moparman2001
Default Won't start unless holding the throttle
I have a 01 ram 5.9l sport everything has been replaced on it less than a thousand miles on engine just out of nowhere it doesn't want to start then it starts and runs fine but smells very rich, on my way home dies at a light but now won't start unless holding the throttle down but when I let off the throttle won't stay running. Any ideas.
Old Dec 29, 2018 | 05:35 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Coolant temp sensor, iac, or TPS. When was the last time the throttle body and IAC was cleaned?
Old Dec 29, 2018 | 01:23 PM
Moparman2001
it's all newer
Old Dec 29, 2018 | 02:07 PM
MoparFanatic21
Originally Posted by Moparman2001
it's all newer
What brand IAC? You can only use Mopar
Old Dec 29, 2018 | 03:11 PM
Moparman2001
All OEM
Old Dec 29, 2018 | 03:36 PM
Is that an airgap manifold I see there?
Old Dec 29, 2018 | 04:04 PM
Moparman2001
Yeah air gap bigger throttle body fuel rails accel injectors harland sharp roller rockers it's not stock
Old Dec 29, 2018 | 09:44 PM
Not even remotely.
I would suspect IAC. Are you getting any codes?
Old Dec 29, 2018 | 10:45 PM
Moparman2001
No codes ?
Old Dec 30, 2018 | 08:10 AM
Start by cleaning the throttle body REALLY well. Pull it off, clean it up, put it back on, and see if anything is better. There is a DIY on the faq section for that I do believe.
