P1389 Code after new PCM
Old Jan 6, 2019 | 04:13 PM
  #31
DerTruck's Avatar
DerTruck
I can only go by the manual online, it should have 5 ranges in DC voltage mode. But the easiest is to check across the battery and see when it shows 12.xx V. Continuity doesn't tell you anything at his point. Check the power feed to the ASD relay, and then check if the control line for the relay gets power when cranking.
Old Jan 6, 2019 | 04:30 PM
  #32
Chunx89's Avatar
Chunx89
I’m sorry it does have 5 but one setting is millivolts. The wire powering the asd relay would be the red wire/lb ? I’m looking at pg 8w-10-12
https://imgur.com/a/QcNMlFi
Old Jan 6, 2019 | 04:57 PM
  #33
Chunx89's Avatar
Chunx89
Ok the red/lb wire has no power when cranking, I just test it with the red lead right? The black one doesn’t have to be touching anything?
https://imgur.com/a/79MNmJQ
Old Jan 6, 2019 | 06:17 PM
  #34
DerTruck's Avatar
DerTruck
Red/light blue is correct and it should have power all the time. You need to connect the black test lead to ground, preferably the negative battery terminal and use the red to test. That way the mm measures voltage to ground.
Old Jan 6, 2019 | 07:45 PM
  #35
Chunx89's Avatar
Chunx89
So maybe I tested the other wire wrong also? When I tested the sense wire I put the red test lead into the wire by the pdc and the black lead by pcm?
Old Jan 6, 2019 | 08:38 PM
  #36
DerTruck's Avatar
DerTruck
Depends on what "by the pcm" means. If you held the black lead to the pcm case or a ground point nearby that's likely ok unless there are ground issues somewhere.
Sounds like you're out of your element here, do you know anybody who knows his/her way around auto electric/electronic ? Much faster than us trying to talk you through it.
Old Jan 6, 2019 | 09:02 PM
  #37
Chunx89's Avatar
Chunx89
If I did I wouldn’t be here lol, so now I know you need to ground the black one out regardless. Tomorrow I’ll check it out, won’t learn unless I do it myself. I’ll get the alligator clip set and keep it plugged into ground. I thought the multimeter had a set ground in it
Old Jan 7, 2019 | 09:28 AM
  #38
Not so lucky. Need a complete circuit.
Old Jan 7, 2019 | 04:45 PM
  #39
Chunx89's Avatar
Chunx89
Ok so the dark green orange trace wire has 12 volts from pdc to pcm when turning key over and when engine cranks.
Old Jan 7, 2019 | 10:46 PM
  #40
DerTruck's Avatar
DerTruck
Please clarify: There is 12V on the DG/OR wire when the ignition is on or only when cranking ? It should only be on when cranking. Also confirm is 12V is present all the time during cranking or only for a second or two ?
In any case the next step is to measure the voltage that the PCM "sees" between the DG/OR wire and the PCM ground. There are two black/tan wires on connector 1 of the PCM, these are the PCM ground. Also have a close look at connector one if there's any sign of burn around pins 31/32 which are the ground connections.
