won't run at idle
Old Jan 3, 2019 | 06:45 PM
dbdesigns's Avatar
dbdesigns
Default won't run at idle
I have a 99 dodge 2500....I can get it to run while giving it gas but as soon as I release it the truck stalls?
I don't want to start replacing things that don't need it so I was wonder if you guys can point me in correct direction
Thanks
Mike
Old Jan 3, 2019 | 07:15 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Thanks
Mike
Last time tune-up was done (throttle body cleaned and IAC, plugs, wires, distributor and rotor)?
Old Jan 4, 2019 | 08:06 AM
dbdesigns's Avatar
dbdesigns
as far as tuneup possibly a year maybe little more
I have sprayed throttle body with cleaning spay but that has also been a yr or so
Old Jan 4, 2019 | 10:00 AM
Need to be more thorough than all that. Disconnect the the battery, pull the throttle body, remove the IAC, and clean everything REALLY well. ESPECIALLY the IAC well. Put it all back together, hook up the battery, turn the ignition to "on", NOT start, count to ten. Start the engine. If everything else is up to snuff, should fix it.
Old Jan 5, 2019 | 07:47 PM
2bit's Avatar
2bit
Mine did that. The IAC valve was bad.
Old Jan 8, 2019 | 07:12 PM
WhiteSnake91's Avatar
WhiteSnake91
I second cleaning the throttle body and IAC and IAC passage, my truck would randomly stall when going from park to reverse or from drive to reverse when backing out of my parking spot....3 filthy rags and some carb cleaner later the TB and butterfly valves and the undersides as far as my finger would reach was pretty decently cleaned of gunk as well as IAC and IAC passage. I didn't remove mine to do it 100% proper, didn't want to disturb some thick metal fencing wire a previous owner hooked up to the kickdown trans cable to the throttle bracket when the stock plastic end connector apparently broke....hey, if it works...it appears to be stronger now than from the factory :P
if you're gonna do it proper, get another gasket for the throttle body too. Haven't had any issues since, and truck has much better power now too.
