2nd gen
Old Jan 24, 2019 | 03:52 PM
Zeb Forsman's Avatar
Zeb Forsman
Default 2nd gen
I just put new spark plugs in my 5.2 liter 01 Dodge ram 1500 and now it smells like sulfur /burning something and is lacking power now any ideas????
Old Jan 24, 2019 | 04:06 PM
What plugs did you install? Do anything else while you were under the hood?
Old Jan 24, 2019 | 05:07 PM
Zeb Forsman
Champion copper plus pulgs is what I put in and the only other thing is I put new wires on
Zeb Forsman
Champion plus plugs and also new set of wires
Old Jan 24, 2019 | 05:08 PM
Those should work fine.... Pull a couple of the easy ones, see if they are wet.
Old Jan 24, 2019 | 06:10 PM
Spillage's Avatar
Spillage
Did you gap them, or just install out of the box?
Old Jan 24, 2019 | 10:44 PM
Zeb Forsman
They were pre gapped and I checked just to make sure and they were all correct 0.040 and also just pulled all the plugs none were wet
Old Jan 25, 2019 | 09:16 AM
Check fuel pressure.
Old Jan 25, 2019 | 10:07 AM
Crossed the wires up?
Old Jan 25, 2019 | 10:39 AM
Ramman18's Avatar
Ramman18
Wire touching exhaust manifold? Did you do the TSB reroute? All wires clicked properly on both cap and plug? Did you replace the cap and rotor, too?
