Flickering / Dimming lights
Old Jan 29, 2019 | 06:02 PM
nyrainman's Avatar
nyrainman
Default Flickering / Dimming lights
Hey All - I never noticed this before, but tonight I had to plow a small area and my plow lights started to flicker and dim, as well as my dash lights ever time I moved the plow. If it did this in the past, it was minimal, as I can't remember. It dims quite a bit. Just the other day I did check the battery and it was okay.
I did read some place that the truck will do this if it's not heated up, but I don't know. I just don't want to get stuck any place.
Running a 1995 ram 2500 V10.
Old Jan 29, 2019 | 07:02 PM
Moparite's Avatar
Moparite
Did you load test it? May want to check the battery terminals also.
Old Jan 29, 2019 | 08:43 PM
And grounds. On some trucks, we needed to install additional grounds on trucks with plows..... (body/frame to battery) Check/clean the ones ya got.
