2nd gen grille cover
Old Jan 30, 2019 | 12:48 PM
V10Burnouts's Avatar
V10Burnouts
Default 2nd gen grille cover
This cold blast here in the midwest has me thinking about grille covers. With an oversized fan and radiator on my v10, it doesn't like getting up to temp, unless I'm on the interstate, especially now that its -20. So, would it be worthwhile to build a simple cover that bolts onto the grille to keep the engine warmer during my short, daily drives? And would it be worthwhile to leave the bottom slots open?
something like this?
Old Jan 30, 2019 | 01:25 PM
Ramman18's Avatar
Ramman18
Absolutely. I use one every fall in wa and it only gets to 32 out here. I use a 180 tstat and it helps warm up and heater temp and mileage. One report I read said to leave a gap in the middle for the fan clutch. Don't know how significantly that helps but I do it. There used to be winterfronts for sale a good decade ago but not anymore. If I was in the Midwest right now, I'd cover up! And I'm from mn!
Old Jan 30, 2019 | 03:12 PM
I live in southern michigan, currently, it's like -11 outside....... I never put anything over the radiator/grille. The engine still gets up to temp, and the heater works as well as you would expect when it is that cold out.......
Old Jan 30, 2019 | 03:17 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I'm right there with you
Old Jan 30, 2019 | 05:17 PM
fj5gtx's Avatar
fj5gtx
Old school solution: piece of cardboard cut to fit in front of the rad.
Old Jan 31, 2019 | 12:47 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
That's what I did for my 440 station wagon and dad did it to a Celica in da UP back in the 70's.
Old Jan 31, 2019 | 12:51 PM
V10Burnouts
Alright. I might try it.
Old Feb 1, 2019 | 11:11 AM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Also, if it works to well, you can trim the cardboard down.
