No bu5 when Can bus is plugged in
Old Mar 4, 2019 | 04:14 PM
Matthew_P's Avatar
Matthew_P
Would it be the harness that I put in for the overhead console? I made sure the dash didn't pinch the wires during install, but could it have done damage to it, even though it has protection? Another question: Can the PCM be at fault just for Ccd and still be good for the vehicle operating?
Old Mar 4, 2019 | 04:37 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
could be the harness but I highly doubt it's the pcmr. Although it could fail the whole ccd would have to fail. You may not have the 2 plug ctm. Look under your dash you should see a box to the passenger side of the steering column with either one or two plugs. Let me know how many plugs you have
Old Mar 4, 2019 | 04:39 PM
Matthew_P's Avatar
Matthew_P
2001 dodge ram 2500
Old Mar 4, 2019 | 05:15 PM
Matthew_P's Avatar
Matthew_P
1 plug but isn't the second plug for if I have powered seats, and with the CTM it did work.
Old Mar 4, 2019 | 05:17 PM
Matthew_P's Avatar
Matthew_P
along with the day it did work. I hooked the console up to test before I installed it, and there was nothing wrong.
Old Mar 4, 2019 | 05:24 PM
Matthew_P's Avatar
Matthew_P
When I bought the overhead console the light switches had popped out, and I had to replace them. I spliced the new switches on. The switches have 2 black wires and 1 yellow wire. I swapped the black wires for both sides by mistake. I installed it, and the 3rd light in the headliner would stay on all the time unless I disconnected the batteries, or turned on the lights on the console, but during that time, the trip computer worked excellent. When I unhooked the console to fix the wires, the light issue went away. I reconnected 1 of the 2 batteries for a brief test, and saw Ccd and No bu5, and the Ccd bus for the console hasn't worked since.
Old Mar 4, 2019 | 05:25 PM
MoparFanatic21
I'm thinking without the highline ctm (2 plug) you can't have the highline overhead console. It took our a while to realize it shouldn't be there
Old Mar 4, 2019 | 05:31 PM
Matthew_P's Avatar
Matthew_P
If thats the case, would it have not worked at all then, and then why would it have been prewired. The forums that I read didn't specify what CTM I had to have. Just the Travel convenience group wiring which I think I have.
Old Mar 4, 2019 | 05:39 PM
Matthew_P's Avatar
Matthew_P
There are CTMs with a white connector, Ones with a green connector, and some with both connectors. I have the one with the green connector. What is the difference between the three.
Old Mar 4, 2019 | 06:22 PM
MoparFanatic21
one is base (1 plug) one is highline (2 plugs) and then the third one is with factory key fob (also 2 plugs) you need either of the ones with 2 plugs as the overhead console filled through that
