Thinking GM style battery conversion
Old Feb 12, 2019 | 06:47 AM
Moparite's Avatar
Moparite
I guess you haven't had the displeasure of removing them after they are corroded. The whole terminal turns with the screw, Then after you do get it off good luck cleaning them. I think they can't transfer as many amps as the standards either just due to the surface area it contacts the terminal.
Old Feb 12, 2019 | 10:00 AM
I have had side post terminals corrode to the point of a no-start condition in the recent past. (wifes van.....) It isn't as prevalent as the top post batteries, but, it still happens.
Old Feb 12, 2019 | 02:20 PM
fj5gtx's Avatar
fj5gtx
Ah it's just a standard side post thought something was special about it. I think I'll keep my top posts just upgraded the connectors. I have a disk battery setup for attaching accessories
Its not a post, its a terminal. nothing sticking out, just a threaded hole and a flat spot for the cable to contact with. Someone mentioned you can screw in an adapter that turns it into a post, but then you're dealing with the clamp issues.
Right now, the clamp has stretched or the post has shrunk, and the issue is there is no more adjustment in the clamp - its bottomed out yet not tight. I picked up a set of these to compensate until it gets warm again - then I'll do it right.
Old Feb 12, 2019 | 02:28 PM
fj5gtx's Avatar
fj5gtx
I've been using CRC battery terminal protector for years for top post batteries. Reapplied at oil changes, tends to keep things from corroding for a long while. On the GMs, maybe I'll take the terminals off and grease the contact - and maybe I'll spray a little terminal protector over it once its together. Nothing like I do for top post.
Old Feb 12, 2019 | 02:43 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I bought a "kit" at Walmart. It came with the pads that go under the battery terminals and a spray by NOCO I think and never had anything corrode. I go through terminals like water because I am trying to find the perfect terminal to connect accessory wires to.
Old Feb 12, 2019 | 04:08 PM
fj5gtx's Avatar
fj5gtx
You should consider something like these... figure out what you need to connect, and multiple vendors sell all kinds of configurations.... They also do top post styles too if you're wedded to that idea; you won't find these walking around WalMart
Old Feb 12, 2019 | 05:02 PM
fj5gtx's Avatar
fj5gtx
Interesting article...
https://www.hemmings.com/magazine/hc...n/1675823.html
Old Feb 12, 2019 | 05:12 PM
MoparFanatic21
I wired in a fuse box but I still have my winch wires connected. I tried those and nothing really looks clean in my opinion. Maybe I'll make some of my own
Old Feb 12, 2019 | 06:47 PM
rebeltaz83's Avatar
rebeltaz83
Does nobody use the penny trick anymore??
Old Feb 12, 2019 | 07:51 PM
MoparFanatic21
What is that?
