Help with diagnosis.
Old Feb 26, 2019 | 05:49 PM
Check the end of the gauge that screws onto the fuel rail. Is the little nipple in there that is supposed open the schrader valve??
Old Feb 26, 2019 | 05:58 PM
smoky614's Avatar
smoky614
Yep, yep. And I get fuel out of the relief valve when I push it. But it is a 0-100, so since the 50psi marker is only bout a half inch above zero. So maybe there's enough pressure to start, but not to read?
Old Feb 26, 2019 | 06:00 PM
Screw it on nice and tight, and just cycle the key a few times, to make the fuel pump run repeatedly. See if the needle does anything at all.
Old Feb 26, 2019 | 06:17 PM
smoky614's Avatar
smoky614
Alright, well scratch that 1/2in thing I was talking about if you ain't already. I was looking at the wrong side, 100psi gauge, obviously 50 alot more then a 1/2in! But I did finally get her to move, All be it not very much, she's chilling at about 4 or 5psi, so fuel pump?
Old Feb 26, 2019 | 06:27 PM
fj5gtx's Avatar
fj5gtx
If the regulator is in the fuel pump (I think it is for the 2nd gens) and you have no constrictions, you could pull the pump and see whats up. Pickup might be clogged in the tank, or the mechanism just doesn't have any life in it. Pulling the pump out isn't easy, because the bed tends to be in the way of removing the pump from the tank. Lots of workarounds on this site... some people cut a hole in the bed, some unbolt the bed and just loosen the rear bolts, and lift that end with an engine crane, etc....
Old Feb 26, 2019 | 06:33 PM
smoky614's Avatar
smoky614
It sure is and yeah, I've always been afan of the hole cutting thing? But if it still sounds like a pump then id have to pull it out anyways, might as well give it a look before putting a new one in. But AutoZone wants 150 for the cheapest so If I need one it'll be from Amazon, 50bucks with a two year warranty so it'll be a few days before I get it. How would I know if it's the regulator or pump?
Old Feb 27, 2019 | 10:16 AM
If you enjoy changing fuel pumps, buy the cheap one. If you only want to do the job one, get a denso, or delphi pump. Yeah, its significantly more expensive, but, change it once, and don't worry about it again.
Old Feb 28, 2019 | 11:17 AM
smoky614's Avatar
smoky614
Believe me, I know you get what you pay for and I appreciate the heads up. But I plan up swapping out this year so I'm hoping itll last long enough! And I'll let y'all know how it goes.
Old Mar 3, 2019 | 09:57 AM
smoky614's Avatar
smoky614
Just wanted to say good call on the pump, she's running like a champ so far!
Old Mar 3, 2019 | 09:59 AM
Good to hear.
