Another Wild vents, but my odd case...
Old Feb 24, 2019 | 07:09 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Yep, it's a common problem as the trucks aged. I don't think they originally came with two check valves, may have come with none..... don't know. Will the additional canister make a difference? Depends on the size. Bigger it is, the less of an issue it will be. Might even be able to find room under the cowl to mount it. So, out of sight.
They had none installed from the factory but issued a TSB and installed a check valve the size of a 52mm film canister (size of the reservoir)
Old Feb 24, 2019 | 09:34 PM
River Brooks's Avatar
River Brooks
Smile
Okay thanks guys, tomorrow I will get once from autozone, the black circle universal one again. Install it after the HVAC check valve and report back. Fingers cross this works!
Old Feb 25, 2019 | 01:22 AM
MoparFanatic21
They didn't use one like that but it might work they used this one on the HVAC line.
Old Feb 25, 2019 | 02:15 PM
Moparite's Avatar
Moparite
You can read the tsb here. Make sure you put the the check valves on the correct way or they will do nothing to solve the issue. I replaced my check valves with napa units. https://www.napaonline.com/en/p/NDP7301349
Old Feb 25, 2019 | 10:01 PM
Sure they will. If you install them backwards, the vents won't work at all.
Old Feb 25, 2019 | 10:28 PM
River Brooks
This is the one I ordered from there today, will this work?
https://www.autozone.com/engine-mana...E&gclsrc=aw.ds
Old Feb 25, 2019 | 10:51 PM
MoparFanatic21
That is a big reservoir. It will work (I'm not sure if it has a check valve in it) but will have to be mounted
