04 Dakota limited slip?
Old Mar 1, 2019 | 09:33 PM
mcdust's Avatar
mcdust
Default 04 Dakota limited slip?
Hey, Have a nice Dakota that I was always sure the L.S. Diff worked fine on by the way the rear end wanted to meet the front coming out of a rainy intersection. The other day I had one wheel on ice and the other on snow and no go. tried two footing it and backing off a bit, all the usual tricks, no dice. 40 k miles, oil about 4 years ago. Whats up?
Old Mar 2, 2019 | 09:16 AM
Get a build sheet for your truck from here. See if it actually has a LSD.
Old Mar 9, 2019 | 10:10 PM
mcdust's Avatar
mcdust
Default Definetely.
On build sheet. Always worked, out sideways plowing etc.
Old Mar 9, 2019 | 10:55 PM
00t444e's Avatar
00t444e
Clutches may be worn out, and they are really not that great to begin with. You need a locker if you want maximum traction.
Old Mar 12, 2019 | 05:33 PM
mcdust's Avatar
mcdust
Thanks for the advice!
