Additional Maintenance questions - No issues
#41
#42
Slightly brutal, but quick way to loosen the bolt is to place the breaker bar handle against the frame, and crank the engine with the starter. CAUTION!!! You need to be absolutely certain that you have placed the breaker bar in correct position, because if you get it wrong, there is a serious risk of injury, either man or machine!
#43
OP, best way is the way I did it. Get a long bar on the ratchet and just loosen it really quickly in one quick motion.
#44
Mopar I did that and it actually worked. The main bolt didn’t need much force at all.. really odd. Now I just need the puller tool and I can call it a day there. I’ve been lucky this far, maybe just cause it’s st Patrick’s day. But my luck slipped a little:
I was cleaning the plenum valley of debris so that I didn’t have to worry about pulling the plenum and getting stuff into the engine. I decided to loosen the bolts to make it easier for me when I get it all done. The very front right bolt broke, snapped at about 1/4th the length. I didn’t even apply that much force at all. Not really sure what to do now. I don’t have a drill and tap set so I can’t get it out. Any recommendations? How would y’all do it?
I showed a picture of my injectors a couple of posts back. Only the front left two are like that.. should I replace them?
Also what is the best way to clean the machined mating surfaces where the gaskets go so I don’t ruin them? Just some cleaner and a small scrubber?
Thanks again y’all I’m definitely making some progress!
#45
Thank you guys for the advice and help!
Personally that's up to you
Scotch Brite pad and brake cleaner
Glad I could help!
#46
I do not :/ honestly not sure I’d even be comfortable with one around the engine lol. I could try and drill it out I think? There is a guy in my neighbor hood that is a mobile welder. I’ll call him up maybe and ask how much he would charge to get it out. Interestingly enough it looks like it cleared the cover.. it might just be stuck in the block.. which means I could probably pull the plenum but not put it back in until it gets pulled out.
#47
Front one I had to drill out because it snapped flush with the block. Unfortunately I didn't have correct tap, so now there's a metric thread on that one.
#48
Been there, done that. When I fixed the plenum, I manage to snap right front and rear left studs. Rear one I got out by heating it glowing red with induction heater, and carefully turning it back and forth, adding penetrating oil, and finally threads were clean enough to turn it out.
#49
Battery would be enough., me I just weld a nut on and zip it out. When I changed my plenum no bolts broke on me
#50
Keep the drill perpendicular to the broken stud, and before you start drilling, mark the center with the center punch. Start with small drill bit, it's easier to keep it straight (perpendicular). I usually staer with small, then take the middle size and lastly correct size for the thread. Sometimes it goes so spot on, that I can pry off the actual thread! But usually I just chase the threads with the tap, and blow the shavings off with compressed air.
