horn pad
Old Nov 1, 2006 | 11:14 PM
heymccall's Avatar
heymccall
Default RE: horn pad
Try grounding the steering column from the metal tube to the steel dash frame. My 94's and 95's use a stupid metal clip to convey ground from the column to the dash. It (the clip) surrounds the right hand column to dash nut and stud where the column can slide in event of a collision. There is also a plastic spacer in there. You have to remove the knee brace plastic to see it. There is one stud on each side of the column.
Old Nov 2, 2006 | 01:46 AM
Mayfair's Avatar
Mayfair
ORIGINAL: mattyge
i hear ya i have exactly the same problem, what i did was buy some airhorns hook them up ran the wire to the overhead console and mounted a ford power window switch that i got at the surplus store so i goes off automatically sounds awesome but i dunno if that would pass a safety or not, i plan on running my truck into the ground so i don't need another saftey
That's pretty much what I did except I mounted a horn buton right on top of my steering collum. Works like a champ.
