fule pump - through truck bed
thanks in advance - 2006 dodge mega cab 4wd diesel - fuel pump out - can i do the replacement through the bed - or do i need to drop fuel tank? I have done dropping method - but the bed on this truck is going away in a short time...so cutting is no biggy
And you should really be in the third gen section.
thanks - I will move it to 3rd gen - but to be clear I can access pump through truck bed - the flat bed project is a month out - so it is not like it is going to happen tomoor when the pump work will have to take place = - tbhank you again
