Speedometer Info needed
Old Mar 21, 2019 | 02:04 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Default Speedometer Info needed
Ok so I have to replace the Speedometer pinion gear to a 27 tooth. Does my 96 use a short one or a long one? Also since the index doesn't go below 30 where do I index it at?
Old Mar 22, 2019 | 10:53 AM
MoparFanatic21
Do I have to buy a different adapter?
You want short shaft. Long shaft were generally for cable driven speedo. As for indexing.... that, I am not sure...... give the folks at TransmissionCenter.net a call, they should be able to help ya out.
Old Mar 22, 2019 | 10:59 AM
MoparFanatic21
Thanks partner! Got really dont know how much of a life saver you are.
