I need advice on the wiring for tail lights,When I drive there are no tail lights.bulbs are not bad either.also have issues with parking lights and the overhead lights on top of the cab,none of which come on when I have the truck idled with headlights on.
Devin,😀
It says the recall is for 3500 series only,this is a 2500 gas.My head light switch is good I believe,have changed it out already and same symptoms appeared.Are you an owner of a 96 dodge by any chance?Asking because I have a box almost the size of a relay box that is located on the rear end bolted to the frame,in between the leaf springs basically,it has threaded bolts I guess on the inside that are labeled for the wiring.Will upload pictures soon.
Thx,Devin😀
I have a 96 2500 gas also and i had this problem. I believe the recall should have been for the 2500's also. Reason is the 2500 have more lights than a 1500 but not as many as the 3500. Main problem is amp draw threw the switch. The terminals(both on the switch and the harness) heat up and cause a high resistance condition. You might want to look at the harness where it plugs into the headlight switch.
