Broken Axle Shaft Stuck In Spider Gear
Old Mar 29, 2019 | 10:20 PM
Yukon makes the actual seals that go on the outside. They make them for the 60
Link??
Old Mar 30, 2019 | 01:11 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Link??
Here even EMS Offroad sells a kit. I talked to both a whole bank got can use them with stock axle shafts and can order them separately. I was the first to test these. (It's the cylinder in the picture)
Old Mar 31, 2019 | 01:40 PM
That's a CAD delete kit for the passenger side. The passenger side seal really isn't that much of an ordeal to change. It's the drivers side that really sucks.
Old Mar 31, 2019 | 04:29 PM
MoparFanatic21
That seal fits both sides and got can order just the seals. You have to call them
Old Mar 31, 2019 | 07:12 PM
But there isn't a machined surface on the drivers side axle for the seal to seal against.......
Old Mar 31, 2019 | 07:30 PM
MoparFanatic21
They do recommend new axle shafts burr I got mine too seal but sanding the rust off and it sealed.
