Cruise Control RPM Jump
Old Apr 3, 2019 | 09:01 AM
Ram727's Avatar
Ram727
Default Cruise Control RPM Jump
I have a 2001 Ram 1500 with the 5.9L. I’ve noticed lately when I put my cruise control on around 65 to 70 mph the rpm will be around 1800-2000 which is normal but if I’m going 70 and will the rpm’s jump to 2200 for a spilt second then come back down. Any ideas?
Old Apr 3, 2019 | 09:06 AM
ZEN357's Avatar
ZEN357
Possibly the cruise control switch going bad.
Old Apr 3, 2019 | 10:05 AM
Does it do the same thing when cruising while NOT using the cruise control? If so, change the throttle position sensor. Mine would drop in/out of lockup if I merely looked harshly at the gas pedal......
Old Apr 3, 2019 | 12:01 PM
Ram727's Avatar
Ram727
Nope it doesn't do it if I don't use cruise control.
Old Apr 3, 2019 | 08:39 PM
I bet it does. Find a nice long straight stretch of road. Doesn't matter if it's a bit hilly. Try and hold a constant 55 mph. See if it does the dance.
Old Apr 3, 2019 | 08:44 PM
Ram727's Avatar
Ram727
Nope never did once drive on interstate going 60 and nothing happened
Old Apr 3, 2019 | 08:49 PM
Then it's likely in the cruise switches.
Old Apr 4, 2019 | 07:50 AM
djacobson's Avatar
djacobson
TPS is the most likely cause. Cheap easy fix. I thought I had a cruse control problem on mine for exact symptom. Changed the TPS and its solid now.
