1999 ram 2500 5.9 gas surging under acceleration
Old Apr 19, 2019 | 12:11 PM
  #21
I am more concerned if you see what you are calling the surge with small changes in throttle position. If that's the case, I replaced the throttle position sensor on my truck to fix that.
Old Apr 19, 2019 | 01:11 PM
  #22
Roger_Rabbit's Avatar
Roger_Rabbit
Yeah I just changed that though last month to try and remedy this, maybe it is faulty?
Old Apr 19, 2019 | 05:12 PM
  #23
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Figgered that out. You get good at creative interpretation around here.
Im to blame for that
  #24
MoparFanatic21
What brand? If you used a cheap brand it is most likely bad
Old Apr 19, 2019 | 06:33 PM
  #25
Roger_Rabbit
o
Ok I’ll maybe I’ll get another one and try it.
Old Apr 19, 2019 | 07:15 PM
  #26
Standard motor products if you can. Or, get the OEM part number, then see if you can find one on amazon, or some such. Generally MUCH cheaper than the dealer. (just make sure that it is GENUINE OEM, and not just 'compatible', or whatever other buzzword they use on the cheap china knockoffs.
Old Apr 19, 2019 | 11:49 PM
  #27
Roger_Rabbit
I tried to upload a video to show what its doing, hopefully that worked. Of course I could catch it doing it severely but I think you’ll get the idea.
I also removed the air cleaner to pull the TPS just to have a look and noticed my air intake butterfly valves were wet and slimy. When I opened them with the throttle cable and looked down in(to the throttle body I assume?), it looks black and very dirty down there. I had never bothered to check that before, can’t imagine that’s helping things. Air cleaner is clean and changed regularly since I bought the truck 2 years ago.
Old Apr 19, 2019 | 11:51 PM
  #28
Roger_Rabbit
Video?
Old Apr 20, 2019 | 09:52 AM
  #29
Yeah, video didn't attach.....
Your plenum is likely blown. Standard problem on these trucks. Check out the be-all, end-all plenum thread for more information on that.
Old Apr 20, 2019 | 10:36 AM
  #30
Roger_Rabbit
😆😆😆ok down another rabbit hole I go
