Oil pressure
Old Apr 24, 2019 | 09:12 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The idiot light is a function of the cluster. So, in order to disable that, you would need to reprogram that.... and I am not entirely sure that is even possible.
It's not you could do it simply with wiring though to keep the light off
Old Apr 25, 2019 | 08:07 AM
Think it depends on what year the truck is...... 98 and up, even the oil pressure gauge goes thru the PCM/communications bus.
Old Apr 25, 2019 | 09:24 AM
MoparFanatic21
I don't know how the sensor works bur if it's resistance just put resistors on the return line to fool it.
Old Apr 25, 2019 | 05:22 PM
That would work.
Old Apr 25, 2019 | 05:56 PM
MoparFanatic21
That would work.
There is always a way around anything I will have about 6 gauges when I'm done
