Fuse box clicking before truck will start
Old Apr 27, 2019 | 08:31 PM
nightfox's Avatar
nightfox
Default Fuse box clicking before truck will start
I have a 95 ram 1500 - 5.9L - auto trans. When I turn the key, the dash lights all come on except for the check engine light. There is a rapid clicking noise coming from the fuse box located under the hood next to the battery. The clicking will gradually slow until it comes to a stop, at which point the check engine light goes solid and then turns off as it should when the key is originally turned to that position. The colder the weather is, the longer it takes for this process to complete. If it is 80 or above, the problem doesn't occur and the engine will start and run as normal.
Until the clicking stops, and the check engine light goes solid and then turns off, the truck will turn over but will not start (not getting any fuel I assume). I think there must be a bad connection that has to heat up before the proper contact is made for (maybe the fuel pump?) the truck to start and run.
I apologize if I didn't explain that well enough, if anyone has any advice or recommendations on a possible fix it would be much appreciated.
Old Apr 27, 2019 | 08:58 PM
Torxhead's Avatar
Torxhead
My first guess would be a low battery or bad connections.
Old Apr 27, 2019 | 11:45 PM
nightfox's Avatar
nightfox
The battery has full charge. The engine will crank/turn over before the fuse box stops clicking, it just won't get fuel in order to start and run on its own. Connections on the both terminals are solid. I appreciate the reply, though.
Old Apr 28, 2019 | 08:11 AM
Then you likely have a bad connection somewhere else. Check the PCM connectors, they like to corrode, and cause odd problems.
Old Apr 28, 2019 | 12:54 PM
DerTruck's Avatar
DerTruck
Can you pinpoint where the clicking noise is coming from ? Is it one of the relays ? Specifically the ASD or fuel pump relay, just put your finger on them and you should be able to feel if one is the source of the clicking.
