Automatic transmission whine
Old May 12, 2019 | 09:01 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by Pepsiboy
2bit,
Thanks for the links. Before I can order online, I will need to crawl under the truck to VERIFY which transmission is in it. Too wet here for that now.
Dave
It is a 46RE
Old May 20, 2019 | 05:00 PM
MonteC's Avatar
MonteC
Do you still have the check ball capsule in the cooler line? Thick fluid will cause higher pressure and make a pump whine or even a buzzing noise. A restriction would also cause this issue.
Old May 21, 2019 | 04:28 AM
Pepsiboy's Avatar
Pepsiboy
MonteC,
Not sure if it is there or not. Where would it be located and what would it look like? ?
Dave
Old May 21, 2019 | 07:22 AM
It will be on the cooler line going to the bottom fitting of the in-radiator cooler. Should be right where the steel line transitions to the soft line.
Old May 23, 2019 | 07:13 AM
Pepsiboy's Avatar
Pepsiboy
No such thing on this one. P.O. put in new radiator and bypassed the internal cooler for an external one in front of the rediator. I don't see anything that could be the check valve.
Dave
