Removing fuel rails on 5.9L
Old May 11, 2019 | 02:01 PM
tchristian's Avatar
tchristian
Default Removing fuel rails on 5.9L
Is it possible to remove just one fuel rail on the 5.9 engine? There's a crossover fuel line between the two rails that looks like it can't be removed or replaced easily. I'm just trying to replace one injector on cylinder 5.
Old May 11, 2019 | 02:44 PM
Yep, the back line is at least reasonably flexible.
Old May 11, 2019 | 04:26 PM
tchristian's Avatar
tchristian
Thanks, it flexed fine when I pulled the rail out.
Old Dec 22, 2020 | 12:52 PM
Raybo54's Avatar
Raybo54
I have a 2001 and it has a busted crossover line How did you get the line off I just need to replace this line only
Old Dec 22, 2020 | 06:05 PM
Cut it, and put something similar in it's place. You'll have to split the tube where it is heat pressed onto the nipples on the fuel rails. Be REAL careful with this repair, fuel leaks can get expensive...... Your truck will burn to the ground before anyone shows up to put it out.
