Help with P0753 limp mode
Old May 17, 2019 | 06:21 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by LunaEros
That would be much appreciated. I'm sure I would've figured it out since I've built numerous motors and replaced transmissions among droves of other repairs over my life but a specific video would definitely make it even simpler when I get the money and also help identify what tools I'll need to get if I don't have all the right ones. Still recovering from losing everything I owned for the fourth time in life.
Marriage? If so that's why I'll never get married lol but yeah send me a private message when you are ready and I'll give you the link
Old May 17, 2019 | 06:34 PM
LunaEros's Avatar
LunaEros
Women were the cause of two of them. One from the recession and two from run ins with the law that got thrown out from being profiled.
I'll bookmark this for when I'm ready. Thanks Fanatic.
Old May 18, 2019 | 02:16 AM
MoparFanatic21
You are welcome
Old May 18, 2019 | 08:08 AM
Moparite's Avatar
Moparite
Old May 18, 2019 | 11:11 AM
potentshadow's Avatar
potentshadow
I could use that video myself moparfanatic! I plan on replacing my filter and fluid as well because I don’t know when it’s been done last. I also need to drop my drive shaft to replace the rear output shaft seal which I know I will be leaking atf +4 anyway so might as well do it then.
Old May 18, 2019 | 12:35 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Some need knowledge here, can it be driven with the 8 pin plug off? You won't have OD, but for around town it wouldn't matter. Out on the highway it's a 3 speed, but cars ran 3 speed auto trans for a long time with no OD. Waste a little more gas. The VW bug had a manual shift 3 speed auto back in the day.
Old May 18, 2019 | 02:37 PM
You can, but, there won't be ANY automatic function. You will have to shift manually as needed, also won't have O/D, or TCC lockup. (which means the trans may run a bit warm.....)
Old May 18, 2019 | 03:43 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
Thanks
Old Jul 8, 2024 | 02:41 PM
AnthonyG1983's Avatar
AnthonyG1983
Default P0753 and P1765 codes are showing seems to be in limp mode not shifting correctly
Does anyone know Hydrashocker's test of pulling the 8 pin connector I've seen him say to test if it is an electronic or mechanical problem?
"There is a way to see if your issue is electrical or mechanical on your transmission 42-44RE. Testing instructions for 42RE, 44RE, 46RE, 47RE.
By doing this you will not have an automatic transmission, you will have to shift it completely manual and you will have no Overdrive!
Get under truck on the drivers side and unplug the 8 pin harness from the transmission near the linkage input into the trans, (this is the main plug to the transmission). Start your truck and back out or what not. Now drop the gear shift selector without stopping all the way down from reverse (or Park) to 1st and hit the gas. You should be going now running in first gear. Now shift with the selector to 2nd gear, then into Drive. If everything shifts fine then your issue is electronic, if it shifts the same then it is mechanical.
If the problem is electric:
1. Replace the Output Transmission Speed Sensor.
2. Check the 8 pin harness you disconnected for corrosion.
3. Replace the 3-4 shift solenoid."
I am wondering if anyone knows if pulling the trans control relay in the junction block would accomplish the same thing.
I've also read on here that if the problem is electrical that the relay can be jumped to bypass it as a semi permanent fix until it can be fixed.
Really hope someone is on since I kinda need an answer now.
Old Jul 8, 2024 | 02:47 PM
1765 Needs to be addressed first. None of the solenoids in the trans are gonna work if they aren't getting power.
