Plenum gasket
I recently did a plenum gasket, thermostat, thermostat housing, water pump and gasket and my temperature indicator always reads about 180 which is the type of thermostat I put in. Is there anyway I can make sure the temp readings are actually accurate so I’m not driving my truck at high temps and not realize it?
Well I put the truck on the barn approach, ran the idle up a little and watched the coolant in the radiator... have quite a bit of bubbles..... went for an hour drive... so far temp is running lower. Granted the outside temp is now in the 40s.. will see again when it warns up. Thanks all for the imput
So I replaced the plenum and intake. Was having an issue with it running hot... now I have a #8 misfire and TCC comes up on my scanner... runs like ****...any help is appreciated
The plenum has nothing to do with it running hot. I would check the connections maybe you bumped something
