Speed Sensor location on 97 dodge ram
Old May 19, 2019 | 12:01 PM
Kaleb Dwyer's Avatar
Kaleb Dwyer
So basically I would have to use the 98 Trans and t-case then and it would work just no speedometer? Also would I need the floor shifter out the the 98 for the 4wd? Thanks for all the info so far
Electronics didn't change until 00. The other problem is going to be the t-case shifter, on the 97, it mounts to the trans. The 98 trans won't have the mount points.
Oh yeah I always forget that. SSI he would have took use the 98 transfer case bur then he won't have a speedometer
Old May 19, 2019 | 01:58 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Yes and no. It would work physically but you wouldn't have automatic functions from your transmission as it uses that sensor for data. You have two options.
Get a 96-97 transmission
Or
Take all the wiring, dash, and computers (from the 98) and put them into your truck.
Old May 19, 2019 | 03:03 PM
Kaleb Dwyer
Thanks I appreciate the information and time. Would be pissed if I put that 98 in and it didnt work 😂
Or
Old May 19, 2019 | 03:21 PM
MoparFanatic21
Sorry to be the bear of bad news
