Speed Sensor location on 97 dodge ram
Old May 17, 2019 | 01:07 PM
Kaleb Dwyer's Avatar
Kaleb Dwyer
Default Speed Sensor location on 97 dodge ram
I'm puttin a transmission off a 98 318 on my 97 360 and I heard the speed sensors were in different places and wouldn't work? Does anyone know if they are different or the same?
Old May 17, 2019 | 01:36 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Entirely different. 98 uses the ABS sensor in the diff whereas 97 uses one in the trans or transfer case
Old May 17, 2019 | 02:55 PM
Yeah, the 98 trans won't have the VSS on the tailshaft..... is the truck two, or 4 wheel drive?
Old May 18, 2019 | 11:07 PM
Kaleb Dwyer
Default Transmission Swap
They are both 4wd
Old May 18, 2019 | 11:09 PM
Kaleb Dwyer
Is there anyway I can convert it or make it so my speedometer works? Thanks
Old May 19, 2019 | 12:01 AM
MoparFanatic21
What drive is your truck? 4wd or 2wd
Old May 19, 2019 | 12:03 AM
Kaleb Dwyer
Default Speed sensor
My 97 is 4wd and the donor truck is a 98 4wd
Old May 19, 2019 | 02:30 AM
MoparFanatic21
Use your transfer case and all the electronics inside your trans or it won't work
Old May 19, 2019 | 07:45 AM
Electronics didn't change until 00. The other problem is going to be the t-case shifter, on the 97, it mounts to the trans. The 98 trans won't have the mount points.
Old May 19, 2019 | 10:57 AM
MoparFanatic21
Oh yeah I always forget that. SSI he would have took use the 98 transfer case bur then he won't have a speedometer
