1995 Ram hood won't open??
Old May 19, 2019 | 03:13 PM
ezpower@verizon.net's Avatar
ezpower@verizon.net
Default 1995 Ram hood won't open??
Truck hood won't open?? Cable seems fine, put vise grips on cable under dash and pulled even more still won't pop?? Tried looking through grill but really can't see very good?? Thinking about cutting some of grill to see it better? Any suggestions before I start cutting?? Thanks
Old May 19, 2019 | 03:22 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Pull the cable and at the same time push on the hood
Old May 19, 2019 | 04:19 PM
ezpower@verizon.net
Default Yea tried that!
Tried that ,no good , thanks for replying!
Old May 19, 2019 | 06:55 PM
MoparFanatic21
Sounds like the latch may be stuck. Unfortunately toy will have to cut the grill because that's the only trick I know.
Old May 19, 2019 | 07:47 PM
Isn't the latch behind the condenser though???
Old May 19, 2019 | 09:15 PM
MoparFanatic21
No it sits right above it, I'm pretty sure
Old May 20, 2019 | 06:36 AM
Moparite's Avatar
Moparite
Try spraying some lube into the mechanism. There is a recall on some of the hood latches.
http://dodgeram.info/tsb/recalls/638.htm
Old May 20, 2019 | 09:11 AM
MoparFanatic21
I think that is for the secondary latches
