Fuel injector wires crewed by mice
Old May 26, 2019 | 03:21 PM
01Dodgect's Avatar
01Dodgect
Default Fuel injector wires crewed by mice
01 ram 360 gas. Mice crewed wires on injector 6 crewed thru and 4 and 8 partly crewed. Replaced connectors. Scanners indicates circuit 6 and 8 open. How do i test circuits ?
Old May 26, 2019 | 04:07 PM
Noid light. You can rent one from the parts store, or, just buy 'em. Not real expensive. Plug it in to the injector in question, crank motor. See if the lite flashes.
Old Aug 11, 2019 | 02:16 PM
01Dodgect's Avatar
01Dodgect
Default No light on 8
Noid light does not light on cyl. 8 injector connector. Relay click when tested with test light. Is there any other test i can do or is the pcm bad? Can i swap the pcm or is it need tobe done at a garage? Any tips and advice would be helpfulthanks
Old Aug 11, 2019 | 03:18 PM
Test the wires. Make sure you have 12 volts on one side of the connector, and the wire from the injector connector, to the PCM is good. (continuity test.)
Old Aug 12, 2019 | 06:14 PM
01Dodgect's Avatar
01Dodgect
I have 12 volts at the connector on one wire and continuity from the connector to the pin connection going in the control module.
Old Aug 12, 2019 | 09:27 PM
With the engine running, and everything plugged in, can you probe that wire with a test light, and see if the test light flashes??
Old Aug 12, 2019 | 09:36 PM
01Dodgect's Avatar
01Dodgect
I will try that and get back to you. Using a noid light be the same test?
Old Aug 12, 2019 | 09:37 PM
If you have one, give it a shot. See what happens.
Old Aug 12, 2019 | 09:46 PM
01Dodgect's Avatar
01Dodgect
I did that the other day that circuit did not flash. I checked the continuity between the pins and wire and were both good. I also checked thr injector resitence on the 4 injectors and there were pretty much the same.
Old Aug 12, 2019 | 09:57 PM
Failed injector driver then..... Likely time for a new PCM.
