Pcm install
Old May 26, 2019 | 07:01 PM
tenno89's Avatar
tenno89
Default Pcm install
I hav a 1999 ram 1500 w/a 5.9l. I need 2 kno the proper pcm installation procedure.
Old May 26, 2019 | 07:55 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Unbolt old one
Unplug old one
Reverse the order
Turn key forward wait 15 seconds before starting the vehicle
Old May 26, 2019 | 08:10 PM
tenno89's Avatar
tenno89
Well, see, thts wat i'd think 2. But my old pcm got fried wen i disconnected the negative cable then reconnected it. Wen th cable was very near touchin the negative battery terminal, it sparked/arced & totally shut down. The only thing tht'll happen wen i turned th key on is th odometer will blink.
So, i'm kinda wary bout jst pluggin th new pcm strate in bcoz i'm scared as hell of fryin it again :/
Old May 26, 2019 | 08:12 PM
Disconnect the battery, and make sure the ignition is off when you hook it back up. That process should NOT fry the PCM.
Old May 27, 2019 | 05:38 PM
tenno89's Avatar
tenno89
Any1 else plz????
Old May 27, 2019 | 05:47 PM
HeikIlm's Avatar
HeikIlm
What HeyYou said. There really isn't anything special procedure when changing the pcm. Battery disconnected and key off.
But, if you fry pcm just by plugging it, I suspect there has to be a short somewhere.
Old May 27, 2019 | 06:02 PM
tenno89's Avatar
tenno89
No, it didnt fry by pluggin th pcm in. It sparked/arced & fried wen goin 2 reconnect th negative battery cable. Frm wat all i read up on this, its a prob with rams frm like 97-02.
Old May 28, 2019 | 09:11 AM
99DR's Avatar
99DR
If HeyYou says something, you can bet it's correct. I doubt you'll find better advice, or many who will disagree with him.
Any1 else plz????
Old May 28, 2019 | 02:28 PM
If you are getting a heavy spark when you hook the battery back up, there is a draw somewhere, that shouldn't be there. Does the battery go dead overnight? Is your charging system working properly?
Old May 28, 2019 | 08:12 PM
tenno89's Avatar
tenno89
Hey, thanx all!!! I got th new pcm in and secured/plugged in, hooked th battery up & it fired right up!!!
Ok, a new issue.....its doin wat told me th pcm was th issue in th 1st place. It fired right up, but th odometer is still blinkin & all th gauge needles r jumpin now (they werent b4
I 4GOT BOUT TURNIN TH KEY ON & WAITIN ugh :/
