Help truck request
Old Jun 1, 2019 | 01:13 PM
Right here.
Old Jun 1, 2019 | 04:20 PM
potentshadow's Avatar
potentshadow
EGR valve?
Old Jun 1, 2019 | 04:55 PM
HeikIlm's Avatar
HeikIlm
Only thing I can think of is the transmission temp sensor, which should be located in cooler line.
Old Jun 2, 2019 | 03:02 PM
Charles Teklinski's Avatar
Charles Teklinski
Right here.
Ty it has helped, but I'm still having difficulty
Old Jun 2, 2019 | 03:10 PM
Charles Teklinski
According to the manual I got for hey you. It is a trans temp sensor, but according to the manual that sensor should be inline attached to the incoming line. It isn't there. So the trans line was swapped out or something is wrong with the info. According to autozone and other retailers the sensor is one that goes into the trans. I looked for that too. It's not there either. So in this case 2 wrongs dont make it right. It's not inline and the trans has no location for the sensor. The plug is there and the computer is reading an error, (not hooked up). So the trans was swapped out and the new one doesn't have a place for the sensor. The tags for Id the trans are missing. It's a trans swap with news lines and no temp sensor. I need to trick the comp into thinking the sensor is there and working. I'm told a 100 ohm resistor connecting the plug ends togather might do it.
Old Jun 2, 2019 | 03:13 PM
Charles Teklinski
My code 11. According to the manual it's a cam sensor under the distributor cap. Good luck finding a part number. I have tried. I can get one from buying the whole distributor but not separately. Odd too is that I'm getti g the error and the truck runs. What a mess. Any ideas?
Old Jun 2, 2019 | 05:27 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
That sensor is called "pickup coil" at the parts stores.
Old Jun 2, 2019 | 07:14 PM
The trans temp sensor was optional, and came on trucks with assorted 'heavy duty' or towing packages. You would need to check your build sheet to see if there should be one there, or not.
Old Jun 2, 2019 | 07:57 PM
Charles Teklinski
Ty. That helped. The guy behind the counter said either it works or it doesn't. So why is the truck running and throwing the code?
Old Jun 2, 2019 | 08:05 PM
Charles Teklinski
Hey you. I'm going to try and run the vin # though dodge dealer tomorrow and find out. But, with the plug there, and the computer tossing out the code it's likely it should be a sensor there. If optional they wouldn't sell a new truck in 95 with an engine light on. .. good news my battary tested bad on the truck and my "spare tested out as good-low charge. Tested it after it got charged over night and when I picked it up today and the guy said it tested bad. I told him to test it again with a diffrent tester BC his manager tested it yesterday and said it was good needed charge. So, he did and then said it was good, so when I talk to his boss tomorrow I will have him on bathroom duty for a month. Mean while I am going to test the battary at their competitor tomorrow.
