Which transmission do I have
Old Jun 6, 2019 | 03:30 AM
jimmyjames12's Avatar
jimmyjames12
Default Which transmission do I have
I have been trying to order a new torque converter for
2001 ram 2500 4WD 5.9L Gas
but Autozone had two options the 46RE and 47RE
They also had a TC with 24 splines but I counted 23 on the tip and 27 closer to the transmission drive shaft. which one do I use the 23 or 27 splines?
Got some numbers from the transmission:
TPKTK1531F1949
P52119846AB
846ab
Old Jun 6, 2019 | 07:27 AM
You have a 46RE. The 47 won't bolt to the 5.9 gas motors.
Old Jun 9, 2019 | 10:24 PM
Tyler Willis's Avatar
Tyler Willis
Default 46re
Yes you have a 46re ....which is what I have which can be a pain in the *** or can be a blessing as half the bands can be adjusted through the transmission pan....you can do quite a bit through the trans pan ....shift solenoid pressure switch etc.
