injectors
Old Jun 12, 2019 | 04:56 PM
kman4443's Avatar
kman4443
Default injectors
I have a 2000 dodge ram 1500 5.2 that will not fire the injectors. I have spark and a working fuel pump that when is turned on pressurizes to factory specs. I have to squirt gas down the throttle body for it to run and when that gas runs out it cuts off. It also has a new computer. What could be the issue? Where should I look first?
Old Jun 12, 2019 | 05:57 PM
Cam position sensor. Also known as the pickup coil. It's under the distributor cap.
Old Jun 13, 2019 | 10:21 PM
kman4443's Avatar
kman4443
Thanks! I will check there first. I know it was changed about 2 yrs ago
