Brake light and reverse light problem
Old Jun 23, 2019 | 07:18 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by HeikIlm
Might be the turn signal switch that is bad, because if the turn signals work that means the wiring is good. Also if the cab mounted brake light works, that means the brake light switch is good. So only thing that comes to my mind is the turn signal switch. When the turn signal is not on, switch in center position, both brake lights can be activated. But if the contacts at the center position are bad, brake lights won't work.
You can tear apart the multifunctional switch and clean the contacts, that's what I did and it has worked ever since
Old Jun 24, 2019 | 09:05 PM
SilentzHero's Avatar
SilentzHero
So turns out it is the turn signal switch, I cleaned out the switch and now they work but I am going to replace cause that switch has been acting bugging with my turn signals as well
