2001 Ram 1500 4X4 Aftermarket headlights, only high beams work
Old Jun 22, 2019 | 09:43 PM
GawdRamIt's Avatar
GawdRamIt
Default 2001 Ram 1500 4X4 Aftermarket headlights, only high beams work
I recently purchased a 2001 Ram 1500 4X4 that had Projector Headlights which were fully functional with low and high beams but the low beams were so focused that I couldn't see good, so I purchased aftermarket headlights that only have 1 bulb each (9400, low and high beam in 1 bulb). I replaced the projectors with the aftermarket headlights and I hooked the blue connector to the back of the headlights. Now I only have high beams and parking lights, blinkers. When I take the blue connectors off and put the black connectors on I have a constant high beam indicator and headlights stay on 1 setting (no matter which I choose low or high beam). If anyone know why this happens and how I can fix it I would be very appreciative of that info.
Old Jun 22, 2019 | 09:54 PM
Sport model truck? You need headlamp housings with two bulbs. One for high, one for low.
Old Jun 23, 2019 | 12:13 AM
Firefighter555's Avatar
Firefighter555
Oh man, that kinda bites! With only brights, I bet that you can see much better now.
I cannot recall 100% if the projector lens in your truck had two bulbs or just one. Hopefully, you can exchange the ones that you bought for a two lamp headlight housing.
