2000 Dodge Ram 1500 short wheel base
Old Jul 18, 2019 | 04:33 AM
David Atwell's Avatar
David Atwell
Default 2000 Dodge Ram 1500 short wheel base
Hey I’m new to this forum and haven’t really used one before so here are my problems and questions well to start off I bought this 2000 Dodge Ram 1500 short wheel base 2wd it had the 3.9 magnum well I replaced the 3.9 with a 5.2 magnum I used the pcm and wiring that went to the 5.2 well my problem I’m having is the truck starts and run you can rev it up but I have the famous NO BUS and my dash and I have the transmission temperature light on and the O/D light saying off and seems like the truck doesn’t have any power when trying to drive it ok so my question are is the auto transmission going out and what could be causing my problems thanks in advance
Old Jul 18, 2019 | 07:25 AM
You have an electronics mismatch. What year was the PCM/harness from?
Moving this to 2nd gen ram section for ya. Welcome to DF!
Old Jul 18, 2019 | 10:22 AM
David Atwell
The truck is a 2000 model it did have a 3.9 I removed all wiring that went to the 3.9 I replaced the 3.9 with a 97 model 5.2 I used all wiring that went to the 5.2
Old Jul 18, 2019 | 10:23 AM
David Atwell
And thanks for moving these for me I really appreciate it and thanks your responding and I can get pictures of everything if y’all need to see what I’ve done
Old Jul 18, 2019 | 12:35 PM
DerTruck's Avatar
DerTruck
That's not gonna work, 1997 had a different instrument cluster with a mechanical odometer vs the later models with the digital one. You need a newer PCM. Also, did you swap the transmission with the engine ?
Old Jul 18, 2019 | 01:13 PM
David Atwell
I have the whole cluster out of the 97 will that help me any
Old Jul 19, 2019 | 07:22 AM
No.
A LOT changed in 98, some more changed in 98.5, and yet more changed in 00. You need a pcm from a 98 or newer truck, and it will need to be flashed for the correct year/size engine/trans.
Old Jul 20, 2019 | 06:31 PM
David Atwell
I just received a pcm from a 2000 5.2 4x4 today think it would work
Old Jul 21, 2019 | 08:17 AM
Should work. So far as I know, the PCM really doesn't care how many drive wheels you have.
