Fuel injector replacement tools needed
Old Aug 7, 2019 | 06:46 PM
  #21
99CubbyBlue1500's Avatar
99CubbyBlue1500
Not a bad idea...... gasoline spraying everywhere isn't any fun at all. Just yank the fuel pump relay, and the fuse, in the PDC, crank the engine, if it starts, let it run till it quits. Doesn't hurt to be safe.
Got the relay out. Don't see a fuel pump fuse in the PDC or the dash fuse box.
Old Aug 7, 2019 | 07:17 PM
  #22
99CubbyBlue1500
Thanks google and cargurus.com I located the two fuses. Fuse #3 in PDC and fuse #9 interior fuse box.
Old Aug 7, 2019 | 07:54 PM
  #23
99CubbyBlue1500
The one below the white connector comes off. There is a tube at the back that goes over top of the intake to the right side fuel rail. That one does not come off. My fuel rail bolts are 1/2" just checked.
Can't get the fuel line below the white connector off, even with the quick disconnect tool. Tragic if I remove the rail with it on? Help!
Old Aug 7, 2019 | 08:11 PM
  #24
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Just be careful. Sometimes you have to push it forward then pull it off
Old Aug 7, 2019 | 10:00 PM
  #25
Yeah, what he said. insert the tool, push the fuel line IN, and try and push the tool into the connector as well. (push 'em toward each other) Then the fuel line should pull right off.
Old Aug 12, 2019 | 04:59 PM
  #26
99CubbyBlue1500
The main fuel line going into the rail on the left side. I've seen it where if it isn't disconnected it can crank (mostly on old lines)
Update: Failed to get the fuel line off last week and worked all weekend. However, I rubbed her the right way and sweet talked her this afternoon and got the fuel line off! Unfortunately, I got rained out for today after removing the throttle body. I'll finish it tomorrow, provided the weather cooperates. Thanks for y'alls help!
Old Aug 12, 2019 | 06:37 PM
  #27
MoparFanatic21
Glad to hear it!
Old Aug 13, 2019 | 10:08 AM
  #28
99CubbyBlue1500
Yes replace the plenum gasket and use shorter bolts, most also do an aluminum plate and replace the timing chain with a Cloyes Double Roller.
So I've decided to replace the plenum gasket while I have it apart(Fel-Pro gasket is only $13). You mentioned using shorter bolts. I'm assuming that you mean replacing the plenum cover bolts. Where can I get em? Standard hardware from Ace?
Old Aug 13, 2019 | 10:20 AM
  #29
99CubbyBlue1500
Also, some dude with a YouTube video of his plenum replacement removed ac pump and alternator. Is this required to just replace the plenum gasket?
Old Aug 13, 2019 | 10:23 AM
  #30
MoparFanatic21
You can but if your AC is charged you can just unbolt the whole bracket and swing it aside
