1997 Dodge Ram 2500 rear speed sensor
Old Aug 10, 2019 | 02:50 PM
CumminsDiesel12v's Avatar
CumminsDiesel12v
Default 1997 Dodge Ram 2500 rear speed sensor
Hello I have a 1997 Dodge Ram 2500 12v that I recently swapped to a NV4500 out of a 1999 truck I swapped the tranny and transfer case over and the new transfer case doesn’t have the spot to plug in the speed sensor is there anyway I can wire the speed sensor into the rear end with the original plug?
Old Aug 10, 2019 | 03:33 PM
Your truck wants the VSS in the output of the t-case. Your original t-case *should* bolt up to the NV4500.......
Old Aug 10, 2019 | 03:36 PM
CumminsDiesel12v
The input shaft from the t case is different on the auto trans and the manual trans one..so it’s not possible to wire it to the rear end?
Old Aug 10, 2019 | 03:38 PM
Nope. They return different signals. That would just confuse the PCM.
Whats different? Could you swap the input stuff on your t-case with the new one? Are the both the same case??
Old Aug 10, 2019 | 04:23 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The splines are the same. I do not know of any differences
