To fix or not to fix
Old Aug 22, 2019 | 09:35 PM
  #21
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by 303hunter
Thanks for the info. I’ve looked into replacing the thermostat, and can’t believe how complicated it is. I’ll go ahead and get a water pump.
It's not complicated when you are doing the timing chain
Old Sep 3, 2019 | 07:49 AM
  #22
Prodirt6000's Avatar
Prodirt6000
Update on my truck. I wish I could upload the video. Once in a while when it starts, I need throttle to keep it running and it sounds like a broken down diesel. Banging, knocking, clacking, stinks terrible. My first thought was timing was way off.
Then I shut it off, try to start it and it just cranks. Cycle that a few times and it finally starts and runs normally. Then maybe a few days later it does the banging clanging thing again. Yesterday when I turned key to start I got a single click, no crank, turn key off and try again and it runs. That could maybe be a loose wire or solenoid going I'm guessing
Any ideas where to look?
Old Sep 3, 2019 | 08:44 AM
  #23
Start with the battery terminals, and major connections, both power, and ground. Clean 'em up good.
Old Sep 11, 2019 | 11:25 AM
  #24
Prodirt6000
I checked the codes
12, 37, 54.
12 - Just have to check all connections, clean them up like stated above.
37 - Torque converter clutch solenoid CKT or Trans temp sensor too high or low ----- Open or short in CKT wiring or connectors. Voltage out of range at transmission temperature sensor input. See NOTE #1 below.
Would this cause my funky issue in gear 1 or 2 when I try accelerating around a corner after slowing down it falls on its face/bogs down until I let off and it acts like it down shifts and RPM's increase and I can go again.
54 - No cam sync signal at PCM. No fuel sync (camshaft signal) detected during engine crank. No camshaft position sensor signal was received from the distributor. Problem with the distributor synchronization circuit.
This would cause my crank but no fire issue correct? Would this also cause the raw fuel smell?
Thanks
Old Sep 11, 2019 | 08:46 PM
  #25
Does your truck even have a trans temp sensor? It would be an external sensor on the cooler line coming out the front of the trans, if you have one, it'll be within about six inches of the trans.
Replace the cam sensor. Parts store tends to call them "pickup coil".
Old Sep 22, 2019 | 03:05 PM
  #26
Prodirt6000
Do you think the crankshaft sensor will need to be replaced as well? The cam sensor is in the distributor, correct?
Old Sep 22, 2019 | 05:07 PM
  #27
MoparFanatic21
Depends, it wouldn't hurt but use only A MOPAR UNIT. Yes the cam sensor is in the distributor
Old Sep 22, 2019 | 05:23 PM
  #28
Spillage's Avatar
Spillage
Do you think the crankshaft sensor will need to be replaced as well?...
I would replace any sensor with more than 100k on it.
