Lost power? Need Help with why.
Old Aug 25, 2019 | 07:57 PM
Chase Leske's Avatar
Chase Leske
Default Lost power? Need Help with why.
So I have a 97 1500 with the 5.9. I need to know if it has lost quite a bit of power over the years or if I'm just crazy. Main issues are losing speed at moderate inclines, and cannot hold speed while towing with overdrive even decently light loads. Has trouble holding speed with a 1500lb boat and trailer on flat grade, and cannot with my roughly 4000lb boat. I usually tow with O/D off anyway but should it not hold speed on flat ground in O/D? Recently threw a code for 02 sensor, and I checked plenum and it seemed ok to me? Although it is a stock steel plate.
It burns no oil, has newer plugs, good air filter, etc
All I've done to it is grind up the throttle body a bit (which helped a little) and drill a few holes in my Cat just to make sure. Doesnt seem clogged. Truck has 208k miles. Please help it feels like a damn slug.
Old Aug 25, 2019 | 08:01 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Do a compression check and report back what you find
Old Aug 25, 2019 | 08:03 PM
Chase Leske
Ok am I just looking for weak compression? Will have to run down to parts store tomorrow as my gauge broke a while back. Will the old thumb trick work for now or does it need to be accurate?
Old Aug 25, 2019 | 08:07 PM
Needs to be accurate. Run the test dry first, then add a teaspoon of oil to each cylinder, and test again.
Old Aug 25, 2019 | 09:45 PM
Brokendodge96's Avatar
Brokendodge96
Hey, looking forward to hearing how this goes. Just had my trans rebuilt and I have not been able to drive with O/D on over about 80 or up hills. Once it locks it doesn’t seem like it wants to kickdown (or unlock) until dropping to 2nd due to slowing down or stopping. Also, O/D OFF button will engage O/D but won’t disengage it until coming to a stop. I’m stumped, so far the oil pan gasket, valve cover gaskets, all speed sensors, cleaned all grounds, had another TC built for my tire size and to play around with.
Old Aug 26, 2019 | 08:27 PM
Chase Leske
Test done dry.
Front to back
Passenger 118, 125, 120, 120
Driver 120, 125, 135, 118
2 plugs broke on removal, no fouling or residue on any of them, and oddly enough the truck runs on 2 cylinders lol
Old Aug 26, 2019 | 08:39 PM
MoparFanatic21
Test done dry.
Front to back
Really low do a wet test.
Old Aug 26, 2019 | 09:15 PM
Chase Leske
145 to 150 all across the board with 3ml or half a table spoken of oil. Used an eye dropper to get in the whole. Low weight oil probably 5w or 10w. Dont have any gear oil. Spark plug style tester hand tight, injectors unplugged and 5 strokes per reading.
Think im getting it right? It's been a while since doing a compression test.
Old Aug 26, 2019 | 09:35 PM
MoparFanatic21
Sounds like bad rings, which is why you have little power. Definitely not a stuck valve or a bad head gasket unless it's blown in every cylinder .
Old Aug 26, 2019 | 09:42 PM
Chase Leske
Interesting. What should I be getting? And would it make that much difference? I dont think it's worth tearing into to do rings. I got it on trade for 1500 worth and it's pretty rusty. Also what should the plenum look like? There's no oil pooling but it is a little dark like its seen oil right in the center. Not sure if i should replace that either? Think I'll try some additive products first. Any recommendations? Lucus oil is my first thought.
