Fallen rear drive shaft, truck wont start, front tires won't roll but rear will.
Old Sep 1, 2019 | 07:33 AM
Tommypappas5442's Avatar
Tommypappas5442
Default Fallen rear drive shaft, truck wont start, front tires won't roll but rear will.
Old Sep 1, 2019 | 08:48 AM
What year is your truck?
Old Sep 1, 2019 | 08:51 AM
Tommypappas5442
It's a 2001 1500 laramie 5.2
Old Sep 1, 2019 | 09:13 AM
I was expecting something newer..... they had the recall on the pinion nut on the newer trucks.....
Think I would drop the cover on the rear, and see if there is any other damage. Likely gonna have to do the same for the front. See what's up.
Moving to second gen ram tech for ya.
Old Sep 1, 2019 | 07:11 PM
DerTruck's Avatar
DerTruck
Basics first: Can you shift the transfer case normally ? Put it in neutral and see if the front wheels turn. Also check with the transmission in N.
Can you describe the sequence of events ?
