Front differential install
Old Sep 10, 2019 | 02:10 PM
mooselee77's Avatar
mooselee77
Default Front differential install
I'm in the process of swapping a D60 in my 1994 ram 1500. I'm wondering if there's a sequential order of mounting points, like which bolts should I start with and so on?
Old Sep 10, 2019 | 04:27 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Nope just make sure there are torqued
Old Sep 10, 2019 | 06:21 PM
D60 out of what? If it's from another Ram, so far as I know, they were all 8 lug..... which isn't going to match the rear on a 1500.
Old Sep 10, 2019 | 07:47 PM
mooselee77's Avatar
mooselee77
Yes another ram. I've already done the rear. My problem is getting the arms that attach to the frame to line up with the diff.
Old Sep 10, 2019 | 08:07 PM
I don't think there is any difference between the half ton, and 3/4 ton control arms..... I don't think.... Get the lowers in first, then you should be able to 'roll' the diff to get the uppers to line up.
Old Sep 10, 2019 | 09:15 PM
MoparFanatic21
There is not
Old Sep 10, 2019 | 09:17 PM
MoparFanatic21
How did you tackle the leafs?
Old Sep 10, 2019 | 10:23 PM
mooselee77's Avatar
mooselee77
Thanks for the info guys, was hoping there was an easier way than I've been trying. As far as the leafs go there are none in the front, but the back ones are a direct bolt on.
Old Sep 10, 2019 | 10:27 PM
half ton springs should be 2.5 inches wide. 3/4 and 1 ton springs are three inches wide.... what year was the truck you get your axles from?
Old Sep 10, 2019 | 11:39 PM
MoparFanatic21
Im thinking he got a LD 2500....
