What is this?
Old Sep 17, 2019 | 01:48 PM
99CubbyBlue1500's Avatar
99CubbyBlue1500
Default What is this?
99 1500 5.2
Back drivers side of engine. Any Idea what this goes to? Please help!
Old Sep 17, 2019 | 02:11 PM
It's a vacuum line with a check valve.
Old Sep 17, 2019 | 02:14 PM
99CubbyBlue1500
Thank you! So it doesn't connect to anything?
Old Sep 17, 2019 | 02:45 PM
HeikIlm's Avatar
HeikIlm
Assuming you have 4x4, and that green line goes down behind the engine? If so, that line goes to vacuum switch on top of the t-case. And no, pictured end doesn't connect to anything at the engine bay.
Old Sep 17, 2019 | 05:21 PM
Ramman18's Avatar
Ramman18
Umm, I have the same truck and there's no vacuum check valve to the drive system. Only check valves are on the passenger side and control the vents. And they have to be connected at both ends to actually work as designed. Dodge would never leave a vacuum line exposed.
Old Sep 17, 2019 | 09:10 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
It's the transfer case breather
Old Sep 17, 2019 | 09:16 PM
99CubbyBlue1500
Does the "fitting" pictured connect to anything?
Old Sep 18, 2019 | 12:35 AM
Ramman18's Avatar
Ramman18
Well, my truck is completely different. My breather is up on top of the transmission.
Old Sep 18, 2019 | 03:29 AM
HeikIlm's Avatar
HeikIlm
I just leave this here:
And this is how the vent and t-case breather are located on my '95 diesel. Rather low, I need to relocate them as high as those lines allow.
Old Sep 18, 2019 | 12:26 PM
MoparFanatic21
The factory location is behind the engine
