Loud “clank” When starting and a loud knocking sound when shutting off.
Have a 96 dodge with a 5.9 gas with 141k miles it makes loud raddling noise when i shut it off and there is an occasional knock when when going down the road.
could be all sorts of things ...I would crawl around underneath and check everything for looseness - all exhaust, hangers, etc... cross members and mounts, starter,engine mounts, etc... if nothing becomes obvious at that point, have someone else start it while you're underneath and see if you can see something or at least hear more clearly where your "clanking" is coming from)...
