What is this sensor
Old Oct 15, 2019 | 03:26 PM
soloflite's Avatar
soloflite
Default What is this sensor
Hey Guys, when taking off the intake last week when I pulled the motor, I broke the sensor behind the T-stat housing. Believe it's the temp sensor, but not 100% sure. There is also a sensor to the left of the T-stat housing if looking at the engine from the front also, not sure what this sensor is also. I've circled both. thanks..
Old Oct 15, 2019 | 04:32 PM
soloflite's Avatar
soloflite
found my answer.. temp sensor..
Old Oct 15, 2019 | 06:26 PM
Yep, those are both temp sensors. The one by the heater outlet should be a one-wire sensor, that one is for the gauge in the dash. The one by the thermostat should be a two-wire sensor, and that one is for the PCM.
Old Oct 16, 2019 | 02:49 PM
soloflite's Avatar
soloflite
HeyYou, now more confused based on the parts listed at RockAuto, some are for w/ light or gauge. Nothing distinguishing one wire or two? Do you have a part# for the one that is broken in the above pic so that I order the right one, can't find them in the parts manual either.
Old Oct 16, 2019 | 06:38 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Do you have a temp gauge? If so get the one for the gauge
Old Oct 16, 2019 | 08:42 PM
Looks to me like the one for the PCM is trashed...... That really needs to be replaced.
Old Oct 16, 2019 | 11:00 PM
MoparFanatic21
I most certainly would do both since you are there
Old Oct 17, 2019 | 07:00 AM
soloflite's Avatar
soloflite
guys, that doesn't help me much, yes the one behind the t-stat is destroyed, I did that trying to get the darned connector off and just broke it. Rock Auto lists all w/ gauges, but you say there is also a temp sensor to the left of it also. They are in fact two different sensors w/ different connectors. I want to replace both, but both ARE NOT listed on rockauto, do you have the MOPAR part numbers for both that I need, I can't find them in the Dodge Parts Manual.. thanks..
Old Oct 17, 2019 | 07:36 AM
Ramchu's Avatar
Ramchu
On RockAuto this is what I see for your 1997 5.9 :
STANDARD MOTOR PRODUCTS TS271 for the gauge
STANDARD MOTOR PRODUCTS TX71 for the PCM
These are under the standard replacement parts
Old Oct 17, 2019 | 07:52 AM
soloflite's Avatar
soloflite
thank you!
