96 2500 5.9 CUMMINS auto
Old Oct 19, 2019 | 02:16 PM
Speedy8505's Avatar
Speedy8505
Default 96 2500 5.9 CUMMINS auto
Hello everyone, this is my first post.
My 96 Ram has a 5.9L with an automatic transmission.
I parked it for a few years and it ran fine then, when I decided to use it again the transmission started slipping so I switched out the oil and filter but nothing.
Any ideas on what steps to take next?
I just changed the oil in the pan, I couldn't get to the oil in the torque converter.
Thanks
Old Oct 20, 2019 | 09:40 AM
Welcome to DF! Moving this to Second Gen Ram section for ya.
Old Oct 21, 2019 | 01:30 PM
2bit's Avatar
2bit
Did you adjust the bands? ATF+4 fluid?
Old Oct 21, 2019 | 07:31 PM
Speedy8505's Avatar
Speedy8505
Just replaced the fluid and filter.
Do the bands need adjusting when the fluid is changed?
Thanks,
Old Oct 21, 2019 | 07:36 PM
2bit's Avatar
2bit
Every 30,000 miles if I remember correctly. Also, these transmissions don't pump fluid in park. You need to check the fluid level in neutral or it will read higher than it really is. Stupid design.
Old Oct 21, 2019 | 07:39 PM
2bit's Avatar
2bit
https://redirect.viglink.com/?format...999%3Cbr%3E%0A
Link to factory service manual
Old Oct 21, 2019 | 07:41 PM
Speedy8505's Avatar
Speedy8505
Cool
Thanks
