Ground wires
Old Oct 20, 2019 | 08:08 PM
Jordan Slaney's Avatar
Jordan Slaney
Default Ground wires
I did an engine swap on my 98 dodge ram 1500 5.2L.
My truck wouldnt start but I found out
I had an issue with a ground wire that went to the frame but I got that figured out and the truck ran for about 10 seconds before I shut it off due to enclosed space and no exhaust.
I found the 2 grounds on the passenger side of the motor go to the block but I found one on the driver side that wasnt connected
Can anyone tell me where it goes?
Old Oct 21, 2019 | 04:15 AM
HeikIlm's Avatar
HeikIlm
That would be ground from the engine to the body. Download FSM for your truck from here: and go to the section 8W-15 for grounds. Maybe the exact location is mentioned there. Or, just look for good, clean place from the engine to connect that ground wire.
Old Oct 21, 2019 | 05:33 AM
Jordan Slaney
Ok thank you.
It's been a fight with this truck
Old Jun 7, 2023 | 08:48 PM
devante's Avatar
devante
Default The two 2 wires on the passenger side
I have two ground wires on the passenger side I’m trying to find out where it goes
Old Jun 8, 2023 | 06:48 AM
Moparite's Avatar
Moparite
Grounds go on the back of the heads.
Old Jun 9, 2023 | 09:08 AM
Keith_L's Avatar
Keith_L
Grounds are like parties: the more the merrier. If you can't figure out where the factory anchored them -- or if that area is for some reason corroded or compromised -- any clean metal surface will work. If in doubt, add more.
As long as you don't try to ground to an electrically hot (positive) area, you could have 500 ground wires from chassis to engine to battery to transmission, etc
Old Jun 9, 2023 | 03:14 PM
PR1AWRet's Avatar
PR1AWRet
Veteran: Navy
https://dodgeforum.com/forum/2nd-gen...m-battery.html
