Dodge ram 2nd gen weird transmission issue!
Old Jun 9, 2023 | 04:56 PM
JRS1891's Avatar
JRS1891
Default Dodge ram 2nd gen weird transmission issue!
Hello I am completely new here, but I have searched for a very long time without finding any answer to my problem.
I have a Dodge Ram 1500 1997 5.2L 4WD with 46RE gearbox.
The problem is when the gearbox is cold, for example: I drive away, stop at an intersection and then drive. Then it's like it goes into neutral and the engine revs up,
if I don't slam the brake, the gear is thrown in again. But the gear is in "drive" all the time. After about 10 minutes of driving, the gearbox works as usual, shifts as it should and smoothly.
Probably because it has reached the right operating temperature. But this, as i have said, happens only when the gearbox is cold. Has anyone else had the same problem? And found a solution to the problem? Am very grateful for answers!
Old Jun 9, 2023 | 05:06 PM
aleekat's Avatar
aleekat
Have you checked the level?
Old Jun 9, 2023 | 05:34 PM
JRS1891's Avatar
JRS1891
Yes, changed ATF fluid and filter aprox 300km ago. And the Level is fine.
Old Jun 9, 2023 | 05:50 PM
Need to be sure and check fluid level in neutral. Park gives an artificially high reading.
When mine was doing that, I changed the governor pressure sensor, and solenoid, along with the output speed sensor, and that solved it. Did a band adjustment fluid/filter at the same time.
Old Jun 9, 2023 | 07:04 PM
JRS1891's Avatar
JRS1891
Okay, so you had the same issue as me? The governor pressure sensor and solenoid is accesible under the oil pan right? And the speed sensor is on the transmission?
Old Jun 10, 2023 | 10:26 AM
Yeah, governor stuff is in the trans pan. Get the Borg Warner heavy duty solenoid set. Output speed sensor is on the drivers side of the trans. It just screws in, easy to swap out.
Old Jun 10, 2023 | 10:37 AM
JRS1891's Avatar
JRS1891
Okay! Ordered a kit before you replied, but it says borg warner/new OEM/Aftermarket/performance in the description. It will take maybe two weeks to ship it to Sweden. I will update when i have replaced all the sensors etc..
Thank you for the help!
Old Jun 10, 2023 | 11:57 AM
Sweden? Wow, these trucks got around quite a bit eh?
Old Jun 10, 2023 | 02:05 PM
JRS1891's Avatar
JRS1891
Hehe, yeah they are quite popular here 😃
Don’t see a 1st gen or 2nd gen often, but 3,4,5 gen is everywere
