Coolant Temperature
Old Oct 29, 2019 | 06:57 PM
Ray Wilson's Avatar
Ray Wilson
98 only has one. The temp gauge gets its clue from the PCM via the communications bus. If all the other gauges are working, then the com bus is working. I would be tempted to plug in with a scanner, and see what temp the PCM thinks the engine is.....
Unfortunately I do not have a very expensive scanner.... I should invest in one at some point.
Old Oct 29, 2019 | 07:05 PM
proVIP3R's Avatar
proVIP3R
hnestly id replace the termometer it might be stuck open i have a 160 and it wont even get to operating temp especially when its cold outside it will not get warm so your best bet is to replace the thermostat it might just be stuck and constantly cooling
Old Oct 29, 2019 | 07:15 PM
Ray Wilson's Avatar
Ray Wilson
It is such a pain to get my hands down in there I hope I don’t have to replace it...
Old Oct 29, 2019 | 07:16 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Even cheap ones will list the ECT temp
Old Oct 29, 2019 | 07:27 PM
Ray Wilson's Avatar
Ray Wilson
Unfortunately not the cheap one I have
Old Oct 29, 2019 | 07:46 PM
If it's driveable, go to any of the big chain part stores. Theirs should.
Old Oct 29, 2019 | 07:47 PM
Ray Wilson's Avatar
Ray Wilson
I may just do that tomorrow. It’s not a big deal that I fix it but I just want it to work, dang it!
Old Oct 29, 2019 | 07:48 PM
Well, that's awful demanding of you.
have you changed the thermostat in recent history??
Old Oct 29, 2019 | 07:50 PM
Ray Wilson's Avatar
Ray Wilson
I’ve never changed it. It looks like an *** to get down in there and change it.
Old Oct 29, 2019 | 08:28 PM
it is. Moving the a/c compressor, alternator, and that big bracket out of the way makes life easier. Makes the job faster as well, as you aren't fighting with as much stuff in the way. It *can* be done without pulling that stuff, but, it isn't any fun that way.
