Solenoid service and upgrade kit installation
Old Nov 26, 2019 | 07:30 AM
p0748 Thats a governor pressure solenoid code. That will put the trans in limp mode. (starts in second, no O/D, and probably no TCC either....)
Old Nov 26, 2019 | 08:48 AM
Xombi's Avatar
Xombi
Is the adjusting bolt being level with the locking nut on the front band proof positive that a band or drum is severely worn or broken?
Old Nov 26, 2019 | 06:28 PM
Worn. If you can actually adjust the band to spec, back the adjuster off two turns, and have enough there for the lock nut to grab ahold of..... it'll likely last for a while, but, need to start thinking about a better solution. Various folks make "slip in" bands, to replace what's in there now. Or, just yank it, and rebuild the whole thing.
Old Jan 4, 2020 | 02:46 AM
Skylor Brothers's Avatar
Skylor Brothers
Default Limp mode
Ive been having the same issue in my 01 with a 99 transmission, did the solenoid fix it?
